Old 03-11-2006, 09:19 AM
dannny dannny is offline
Default Help
I have a problem, idk if its a bad problem or good proble, but sometimes when i shoot single shot with my rocking trigger it shoots two balls really fast instead of one
Old 03-11-2006, 12:51 PM
Default Re: Help
It's one of 2 things...either it's the design of the rocking trigger - that if you don't realize it, when the trigger springs back to it's "rest" position, it still springs enough to trip the top trigger switch.......or....
you need a new detent
Old 03-11-2006, 01:49 PM
Default Re: Help
i also have another problem, on my other esp trigger frame i press the trigger and the top thing on the trigger frame barely goes down so the gun doesnt shoot, it is not the battery because i tried other batteries and its the same
any suggestions?
Old 03-11-2006, 03:18 PM
Default Re: Help
so you hit the top switch and it doesn't fire ?? ... hmm.. maybe the allignment of the triggers messed up and the bottom trigger is bouncing but the top isn't firing ... i'v never had a rocking trigger so this is just my guess
Thought about it and you could have adjusted the top switch too far out and the bottom switch too far in ..
Old 03-11-2006, 04:47 PM
Default Re: Help
i havent adjusted anything, the top trigger shoots fine but wen i press one of the triggers once, it shoots twice sometimes
Old 03-11-2006, 06:36 PM
Default Re: Help
... hmm i think it's bounce ... but im not sure .. .. it's when you just click the noid correct ??
Old 03-12-2006, 06:42 PM
Default Re: Help
yup, it shoots twice really fast when i press one of the triggers
Old 03-13-2006, 01:12 PM
Default Re: Help
Are you sure that isn't a fireing mode on the frame, I've never used one, but it could be like rebound mode press it fires, release, it fires?
Old 03-13-2006, 01:34 PM
big_daddy_d's Avatar
big_daddy_d big_daddy_d is offline
KUSA KREW FOR LIFE BABY
Default Re: Help
More than likely with it being a lighter switch than the regular eframe you just have a bounce issue. The trigger + the vibration of firing= switch being activated more than once in a trigger pull...
Old 03-13-2006, 04:26 PM
Default Re: Help
yeah ... you should probably just adjust the rocking trigger ...
argh i hate rocking triggers... just not something that i'd want ...
