Rules:
Trades:
Feedback: Spyder PBN Old PBN New Timmy MCB Angel ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~ I do not care for or want any of these items. If they do not sale, they will get trashed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~ ![]() #1 Used marker case. Got it in a trade. $10 Shipped ![]() #2 16" Taso Winforce Barrel. Spyder thread. Clean bore, scratchs on tip. $15 Shipped #3 12" Equation Bizerk - Sniper with .693" insert. Spyder thread. Used, got in trade, no major scratchs. $15 Shipped #4 Stock Spyder barrel. Used. Free when you buy $15 or more. #5 12" Taso Barrel. Spyder thread. Used, some scratchs on tip. Electrical tape on ports. Can remove if you want. $15 Shipped ![]() #6 Yellow JT lense. used. No cracks. Free when you buy $15 or more. #7 Clear thermal JT lense. Used. Thermal inside is cracked. NOT THE OUTSIDE LENSE. Free when you buy $15 or more. #8 JT lense frame & strap. Used. OK foam. $10 shipped ![]() #9 Vforce mask. Used. Strap & foam good. Lense good. $15 Shipped ![]() #10 Scott mask. Used. Strap & foam good. Lense good. $15 Shipped ![]() #11 JT Enforcer mask. Used. Strap & foam good. Lense cracked. $10 shipped or $12 shipped with lense from above. ![]() #12 JT mask. Used. Strap & foam good. Lense good. $10 shipped ![]() #13 Used JT strap. Pretty decent condition. $offer Last edited by oldironmudder : 01-05-2009 at 10:58 PM. |
![]() #14 JAM Anti-Chop Bolt. Used / Broke in. Well maintained. Oring on inside is good. $15 shipped #15 Classic Timmy frame. NOT for sale, keeping it. ![]() #16 Silver Bob Long Torpedo. Used. Rebuilt & works. Inlet & outlet marked in yellow. $20 Shipped PENDING MONEY ![]() #17 68ci. 3000psi Pure Energy Steel tank. Got in a trade. Valve lip it straight. Out of Hydro. I have not tested it. Markings: DOT-3HT3000 M9001 A08223 08^00 REE:7.35 AC 0037 6CT - CANADA $25 Shipped #18 OLDER Revvy, Single 9v. Used & works. NOT for sale, keeping it. ![]() #18 2 pair of used armored fingerless gloves. $8 shipped or $5 with $12 or more purchase ![]() #19, 20, 21 200 Round hoppers. Free if you want them when you buy something else. ![]() #22 Homemade stock. Several adjustments. Back plate has some surface rust & a few other spots of rust on the plates. $15 shipped ![]() #23 Homemade Bipod. Does NOT fold up. Fits between barrel & LPC on my TL+. $15 shipped Last edited by oldironmudder : 03-19-2009 at 08:26 AM. |
![]() #24 Stock MR1 Barrel. Got in a lot of parts. Havent used it & havent looked very hard at it. $offer ![]() #25 Small lot of stock MR1 parts. Used. $15 shipped ![]() #26 - 33 USed stock stainless hose. 2 elbows, white missing screw in picture but i have it installed now. Butt plate for 9oz tanks. Older red DYE sticky grip. Has a hole in one side. Game timer grip, need battery. 2 pair of older ESP grips, one in good shape, other covered in duct tape. $ offer on any thing ![]() #34 - 39 Angel G7 button thingys. Stock TL+ ASA, stainless hose & X-chamber. Used noid with manifold. Used older ESP noid, need to resolder one wire back together. Silver RVA. Blue RVA screw. $ offer on any thing ![]() #40 - 53 CP Bottomline adapter, spyder to normal inline holes. $10 shipped Custom brass valve w/ 4 differant lenght valve pins. $10 shipped Field strip screw set, Spyder, used. $5 shipped Cut TL+ barrel shroud. Side cocking bolt. 2 safetys. Random cup seals. RVA w/ screw. Random striker buffer. ESP sear. ESP clear sight window. Random big orings. VA with foregrip. $ offer on bottom 10 items. ![]() ![]() ![]() #54 Used TL-x body. Drilled for eyes (I did NOT drill them). Lower Tube milled for 2k5 Timmy specs. Actually, smaller than Timmy spec but big enough to work. $15 Shipped ![]() #55 - 63 2 stock strikers & 2 cut strikers, all slim. Taso ASA. 2 Stock valves. NDZ valve. # full body valve spring for spyder. $ offer on any thing Pending Money - NDZ Valve. ![]() #64 Failed Spyder/Cocker project. $12 shipped Last edited by oldironmudder : 03-19-2009 at 08:27 AM. |
![]() #65 2 pair of USMC woodland camo BDUs. Size: inseam, 20.5-32.5 waist, 31-35 $offer ![]() #66 - 67 Cheap scope & decent mount. $offer ![]() #68 Box of talon & stingray parts. Plus one blue working Talon with C/A adapter. $20 shipped (Large flat rate) PENDING MONEY ![]() #69 Box of cheap blowback. 1 random & 2 walmart markers. They worked but will retest before they ship. $30 shipped (all three) Last edited by oldironmudder : 03-19-2009 at 08:28 AM. |
full body springs
James you know what i wnat, Ill PM you though
Team Retribution. Quote:
trades for #68? pm me
Mini for Spyder!!!!!! EspeciialyPsycho (6:52:41 PM): i hustled $25 fromt he kids at school today mrpurplehawk (6:52:55 PM): your joking? EspeciialyPsycho (6:53:13 PM): no mrpurplehawk (6:53:25 PM): nice EspeciialyPsycho (6:53:33 PM): haha EspeciialyPsycho (6:53:45 PM): owned them at yu gi oh |
