Old 03-21-2008, 05:22 AM
gregbolby gregbolby is offline
Default qloader-do i need sp8 mod kit?
do i need this to mount the qloader or can i just make a bracket?
does it come with any kind of diff feed neck etc
Thanks
G
Old 03-22-2008, 05:21 PM
KingTutBaller's Avatar
KingTutBaller KingTutBaller is offline
PWP Elite
Default Re: qloader-do i need sp8 mod kit?
I made my own bracket, it's not very many posts back, here's the link
http://www.spyder.tv/forums/showthread.php?t=15825
I've seen some other homemade brackets on here, and some people also use an adapter that fits right onto their feedneck and requires no hose, you can find it on the qloader site and also on rap4 I believe.
Old 03-25-2008, 04:04 PM
ViperX's Avatar
ViperX ViperX is offline
MR2 X-style
I made a direct feedneck out of a 3/4" CPVC connector, cut it in half, sand the outer diameter down to give it a nice snug fit and filed out a flat groove and used a heated x-acto blade to melt a small slot for the metal ball stop.(probably not even needed in the direct feed configuration but will prevent possible breaking of balls when twisting the pods on and off)
The inner diameter was an exact snug fit with the MR2's stock feedneck. It's so tight even with a loaded pod, I don't even have any clamps or set screws holding it in place and there is no wobble.
Cutting out the need for hoses and eliminating the cluster of balls that slide around in there makes this setup a lot easier to work with IMO.
That and it cost less than a dollar........
Old 03-25-2008, 04:14 PM
Thats the same thing that i did with my Q loader I didnt add the metal ball stop though I just ground one of there fittins flat and left it inside to hold it. Geez Viper looks like im tryin to steal all your ideas!
General Shawn Wayne Tetz, Commander 187th Gaurds Mechanized Rilfe Division.
- Includes the 3rd armored brigade from the 34th Gaurds Armored Division. (APC's and armor as well as support elements)
-UCSF Armored Division Commander
Armored Units
-Deep insertion APC
-Killer "B" Battle Tank
-Troop Transport APC (almost done)
-Gun Truck heavy support unit (In the works)
-Order of Lenin (1st)
-Skyline Sergeant
-YGP Rep!
-Sector 4 team feild honor recipiant (UCSF)
Old 03-25-2008, 04:23 PM
ViperX's Avatar
MR2 X-style
Great minds think alike right?
Old 03-25-2008, 04:25 PM
Guess so! have anymore great ideas or do i have to try to copy them the hard way! LOL
Armored Units
-Deep insertion APC
-Skyline Sergeant
-YGP Rep!
Old 03-26-2008, 12:32 AM
Jungsa's Avatar
Jungsa Jungsa is offline
Thread Killer
I am wondering what you do when you have to switch pods... Do you use a side arm? carry grenades?
Modified Dye Stickies-
2" Side rail- reg' rail attached to the side by a screw
Halo B w/ RIP drive-
Core MR clamping feed neck
Maddman Spring kit-
J&J Allstar edge barrel kit
Mamba coil remote
Want:
better paintball skills
Old 03-26-2008, 03:35 AM
SpyderMan723's Avatar
SpyderMan723 SpyderMan723 is offline
TJ
its not like it takes 5 minutes, just pop it out and throw a new one in
Old 03-26-2008, 08:36 AM
"SOL" rings a bell. You'd fill extra pods and put them in a pack that fits them (they're bigger than a standard pod, obviously), and swap them out on the field. Takes about 30 seconds if you're doing it slow.
Old 03-26-2008, 11:58 AM
ViperX's Avatar
MR2 X-style
lol....funny! I'm really kinda speechless.....
