Old 08-10-2008, 09:51 AM
Salzy Salzy is offline
Default Need some help with Xtra problems
Hi, I'm new to these forums and I came here looking for some help in fixing my Xtra paintball marker. I haven't paintballed in a few years now and am looking to sell my gun. However, it leaks CO2 whenever I attach the canister and I don't want to sell it when it's not in working order.
I had the same problem a long time ago and was able to fix it after talking with a technician on the phone. I've pulled the gun completely apart 4 or 5 times now and can't seem to find the problem. The CO2 seems to leak from somewhere around the tube/valves coming from the grip. (sorry, I don't know any of the actual part names or anything)
Can anyone help me to solve this problem? Links or anything? Some of the links in this Xtra forum didn't lead me anywhere or wouldn't work. To be honest, I'd rather not do it myself and have to pull it apart again. I'd much rather send it to a technician to fix it if that's possible. Please let me know what my options are. Thanks a lot guys.
Old 08-10-2008, 11:53 AM
SupaSnipa's Avatar
SupaSnipa SupaSnipa is offline
The Gumpster
Default Re: Need some help with Xtra problems
When you took it apart did you change the or rings? My guess would be a bad o-ring. Another possibility would be the cupseal. Did you buy your marker new? If you did you might have a parts kits with the necesary objects in them.
"You gas up the marker, put on the gloves, strap on the mask, and walk onto the field.. it doesn't matter that you failed a test, that your girlfriend broke up with you last night, or that you got a ticket on the way there. Your world is right for the next couple hours. This is your heaven on earth. Live it. Love it. Paintball for life."
Red Proto jersey, USED ONCE!
Old 08-10-2008, 07:01 PM
I bought the marker new, but it only came with a small baggy of other parts. The O-rings in the bag are the larger sized ones, but none that size looked bad when I pulled the gun apart. Neither did the smaller O-rings.
What is the cup seal?
Old 08-10-2008, 11:14 PM
kidonfire's Avatar
kidonfire kidonfire is offline
If you fall down a bottomless pit, you die of starvation.
Location: Thumbing my way home on the side of the interstate
The cup seal is the white piece that screws onto a pin that goes into the valve.
part number 12 in the Xtra 05' manual. (clicky)
Or part number 12A in the Xtra 03' manual. (click me!)
It shouldn't be too hard to replace. If otters site were up now, he had a good explanation of how to disassemble your marker.
Here's a good video of how to disassemble your marker. It's an imagine in the video but it will be nearly exactly the same.
http://www.youtube.com/watch?v=2_qD0...eature=related
Skip to 1:35 and watch until 2:55. That will tell you how to get to the cup seal and valve pin. You should have gotten an extra cupseal with the gun. Unscrew the valve pin from the cupseal(the white piece) and replace the cupseal with the extra one. Then just do the reverse of the video to put the gun back together.
Hope this helps, just tell me if this doesnt make any sense.....
10% luck, 20% skill, 15% concentrated power of will. 5% pleasure, 50% pain, 100% reason to remember the name.
Everything you need to know
Old 08-12-2008, 01:21 PM
SupaSnipa's Avatar
The Gumpster
Old 09-29-2008, 03:18 PM
Thanks for the help you guys. That all made perfect sense, and I did as you suggested. However, it is still leaking CO2 for some reason. I'd love to take care of this in some way. Can I send it in for work by Spyder themselves?
Old 09-29-2008, 03:20 PM
DFSniper's Avatar
DFSniper DFSniper is offline
Official SOC Short Bus Crew
is the valve in backwards? the big hole should be facing the front.
8/23/03 OS KUSA #10898
Spyder to pump conversion tutorial!
Project LP Reposted!
Sales Thread
(7:11:05 PM) Battlechaser: Did you just slaughter George Clooney and steal his mojo..?
"Death doesn't exist. It never did, it never will. But we've drawn so many pictures of it, so many years, trying to pin it down, comprehend it, we've got to think of it as an entity, strangely alive and greedy."
- from Ray Bradbury's Something Wicked this Way Comes
Old 09-29-2008, 04:56 PM
You can send it into Kingman for factory repair if you wish. Their number is 888-546-4626. Give 'em a ring and see what they can do for ya!
Old 09-29-2008, 05:21 PM
I just pulled it apart again and replaced the cup seal with the one in the extra parts baggy. I also checked to make sure the valve was positioned correctly.
I attached the CO2 canister and it still leaked. I found it was leaking from near the hose at the bottom, by the adapter for the canister. I flip-flopped the two hose adapters, and the leak moved up near the expansion chamber/grip. I then flip-flopped the O-rings inside the hose adapters, and the leak moved back down by the canister adapter. So, after all the monkeying around...does it just sound like a bad O-ring to you guys? That seems to be the issue as far as I can tell, but I'm no expert.
In the manual, it tells me they are #011 O-rings. Can I find these at a local hardware store? Or do I have to order them specifically for paintball markers?
Old 09-29-2008, 05:33 PM
DFSniper's Avatar
throw some teflon tape on it, that should fix it.
Sales Thread
