Old 05-14-2007, 12:22 PM
RiotSauce RiotSauce is offline
Default Velocity Issues
Sup all, I purchased a Spyder TL-R Sniper "combo" pack last month-- and it worked pretty well straight out of the box. However, i played paintball yesterday and I noticed that when I fired, the paintball would leave the barrel, go straight for about 10 feet, then completly spiral off-- it was unreal. I know this is due to the velocity, which i quickly adjusted via the quick adjuster in the back *just a little knob you turn* I turned it both in and out and did test shots and the same thing happened... Is my gun defective or could it have been the paint I was using? Thanks.
Old 05-14-2007, 12:27 PM
tater_salad's Avatar
tater_salad tater_salad is offline
Default Re: Velocity Issues
Are you using co2? If you are it might be that.
Xbox Live: Cal3bH
Old 05-14-2007, 12:28 PM
Kenny_McCormic Kenny_McCormic is offline
WILL WORK FOR PAINT!
bad paint or a diry barrel will cause that i can keep pmi super swirl in a 6x6inch circle@50 feet with the gun in my sig
Stock ZAP AMP generator with polished valve assembly
Spyder Victor with a modded CORE derlin bolt, polished striker and polished valve assembly
BEING POOR SUCKS
Old 05-14-2007, 12:31 PM
I used CO2 and my barrel was completly clean. The paintballs worked fine in my friends tippmann 98
Old 05-14-2007, 12:37 PM
acutally-- Im looking at the barrel right now and although no balls broke in it that day, it was-- oily? thats as much as i can describe it.
Old 05-14-2007, 12:38 PM
its the co2 buy a 72/3000 solid bottle of av for $64 if u can afford it
http://www.actionvillage.com/is-bin/...sAAAD5MtFJBmGq
BEING POOR SUCKS
Old 05-14-2007, 12:39 PM
Sigh only problem is I dont think there is anyone near me who does N2... I mean, when i turned the velocity knob, i sensed that the velocity never changed... but who knows
Old 05-14-2007, 12:52 PM
Critical's Avatar
Critical Critical is offline
I didn't do it...No witnesses survived
Switching to N2 isn't going to solve your problem here, even if it is a velocity problem. You say the barrel looked oily? That can easily be paint residue. What type of barrel is it, or is it the stock TL-R barrel? when you were messing with the velocity adjuster, were you over a chrono, so you could see what changes you were actually making? Did you strip down the marker and clean everything before and after the game? Right now, it sounds more like you have a dirty/fouled marker, rather than a velocity problem, especially since you say the same paint worked fine in other markers.
SOC Feedback: +32/-0
"To sit back hoping that someday, someway, someone will make things right is to
go on feeding the crocodile, hoping he will eat you last - but eat you he will"
Ronald Reagan
Old 05-14-2007, 12:59 PM
Yes, the barrel is oily, it was the stock sniper barrel that came with the gun. To tell you the truth it was only the second time i used it-- so i doubt it could be a really messy inside of the gun. I was not over a chrono-- the balls kept spinning how they did no matter what i turned the velocity to. I cleaned out the barrel and even the area where it connects to the gun as that was oily too. Ill fire a few rounds and see how it goes.
Old 05-14-2007, 01:06 PM
Critical's Avatar
First, read this then perform the maintenance as described. Then, chrono your marker to a standard velocity (approximately 280fps). If your marker is still doing it, then look into upgrading parts, looking for problems. Just because a marker is new, doesn't mean it's clean.
Ronald Reagan
