Old 01-25-2009, 06:34 PM
Kunithrayin's Avatar
Kunithrayin Kunithrayin is offline
MR1 Owner
Default Removing Venturi?
Ok I'm sure this is a newbish question but can somebody explain this to me? Exactly which part of the bolt is this? what happens when you take it out? Does it help much with lowering the pressure? And does anybody have a guide on how to do it?
Spyder MR1
16" SP Progressive Barrel
MR3 Tactical Rail
Spyder MR Series Red Dot
Java Gravity Fed Hopper; Camo Duct tapped
Modded MR1/MR2 Stock
Old 01-25-2009, 06:36 PM
TheDarkShadow's Avatar
TheDarkShadow TheDarkShadow is offline
add 1,794 posts
Default Re: Removing Venturi?
look in your bolt, see the star thing? that's it, to remove it, i just used needle nose pliers, if you have a hard time getting it out you may have to heat it up (just slightly)
E-framed Sonix Pro
2009/2010 bone stock sonix
ferret15's Avatar
ferret15 ferret15 is offline
09 SOTM WINNAR!
http://www.sundragonpps.com/paintbal...free_mods.html
just read everything! it will really help.
contact me for custom work
Feedback +18/0
Old 01-25-2009, 07:07 PM
Modded-Like-Hell's Avatar
Modded-Like-Hell Modded-Like-Hell is offline
Double Tomahawk my way threw
yeah the star thing inside the bolt...remove it with a needle nose pliers...i wish i knew back then cuz i used 2 long kebob holders to remove it. it helps with low pressure guns if u are on the budget... porting and polishing the bolt will drop off sum weight and reduce friction. removing the star will make flow better...read ottercustoms
mOddEd LiKe HeLL (1:21:29 PM): i was there from 10pm to 4am
FootInY0Ass (1:22:15 PM): holy **** you dropped it hard last night
mOddEd LiKe HeLL (1:22:57 PM): and i was there thursday and friday
mOddEd LiKe HeLL (1:23:20 PM): thursday, they closed early so we went to the bar up the street afterwards
FootInY0Ass (1:23:40 PM): AA time.......
SOC Feedback : http://www.spyder.tv/forums/showthread.php?t=5392
Ebay Feedback : http://myworld.ebay.com/vicentezarate
Old 01-28-2009, 03:32 PM
MR1 Owner
Can I just remove it though? Or do I have to have a low pressure gun? Right now I've got a stock internals MR1 so would it help anything to remove it now?
Spyder MR1
MR3 Tactical Rail
Old 01-28-2009, 06:29 PM
add 1,794 posts
yeah, just go ahead and remove it
E-framed Sonix Pro
Old 01-28-2009, 06:47 PM
MR1 Owner
I won't hurt anything right? and if it does can it be put back?
Spyder MR1
MR3 Tactical Rail
Old 01-28-2009, 07:25 PM
add 1,794 posts
yeah, it's threaded
E-framed Sonix Pro
Old 01-28-2009, 08:06 PM
yes u will be able too put it back it thread
Old 01-28-2009, 08:42 PM
Zandor Zandor is offline
Can you explain me, please, the objective to remove this little piece? I'm not so good in english and I don't understood too much the link...
Sorry and thank you for your time
Nicolas
