Old 03-22-2007, 01:23 PM
Pwgsx's Avatar
Pwgsx Pwgsx is offline
300 fps
Default LP help
I cant seem to get my new pilot under the 370 mark. I have tried all different spring combo's but nothing seems to lower my psi. I have a Light valve and Med Main right now and that seems to be the lowest I can get.
I have a Palmer Reg, 32 degree valve and pin, I opened up the holes on the vertical adapter. I dont know what else to do.......
LP Spyder Pilot 250psi Stiffi Barrel, NDZ Valve, Palmer Stab., Assault Block, Spring Kit, T-Board with Eyes.
Feedback: http://www.spyder.tv/forums/showthread.php?t=9477
Old 03-22-2007, 01:44 PM
Default Re: LP help
Try the medium valve spring.
Old 03-22-2007, 01:58 PM
Pwgsx's Avatar
300 fps
Default Re: LP help
nope, thats actually worse
Old 03-22-2007, 07:39 PM
Pwgsx's Avatar
300 fps
Default Re: LP help
Whats the best Valve to buy, I have a 32 degree one but that could be the only problem that I can see........any thoughts
Old 03-22-2007, 09:04 PM
shunut's Avatar
shunut shunut is offline
Respected, period.
Default Re: LP help
Its probably your VA. I opened up my VA as much as I could, even to the point that it leaked from the mounting screw hole because I drilled into that and still couldn't get my marker down below 400 psi. Try an aftermarker VA.
Viva La KUSA!
KUSA Feedback
2006 Non-Spyder of the Year - The Shunut Spimmy
Shunut Creations
Old 03-22-2007, 09:16 PM
Pwgsx's Avatar
300 fps
Default Re: LP help
speaking of that, I did, and i even had the airsmith drill it out, I got home and even opened it up more, not thinking I took too much out of where the volumizer screws in and was leaking from the threads, I taped it up and put on some putty on those threads and its good to go. It help a bit but not a big difference.
Im thinking its the valve?? Its the only thing thats not really that great, I read that the 32 degree valve is not good.....any thoughts, I was looking at a Madman Rocket Valve for Spyder
thanks for the ideas so far.....
Old 03-22-2007, 09:25 PM
shunut's Avatar
Respected, period.
Default Re: LP help
The Maddman Valve is nice, that what I had in my TLX. However even with the Maddman and my stock VA drilled out, I couldn't go lower than about 350 psi. Once I got an aftermarket VA, I dropped to 240psi @ 285 fps, consistently.
Also, remember that just because you go lower, doesn't mean its necessarily better. You need to find the pressure that your marker performs the best. Good performance means its consistent, your velocity stays +/-5 and you are getting good efficiency.
Viva La KUSA!
KUSA Feedback
Shunut Creations
Old 03-23-2007, 02:35 AM
Default Re: LP help
I think a lot of people get hung up on the 200 or lower mark like it's the magic number. My pilot works best at 325, although I can go lower, it's at the loss of accuracy and efficiency. An o-ring bolt really helps when tuning LP as well, a lot of wasted gas is lost there.
Old 03-23-2007, 04:46 AM
bamf-hacker's Avatar
bamf-hacker bamf-hacker is offline
Bling Bling Bling
Default Re: LP help
AKA Tornado Valve is a good LP High flow valve for Spyders. The nice thing is you don't need to modify the valve stem.
I used that in my LP Rodeo and got it down to 250psi @ 285fps and it was consistent. I could have gone much lower but sacrificing consistency.
Look at the Spyder Bible www.ottersccustoms.com and you will see the best products for a LP Spyder.
Originally Posted by TheRedBarron
secks comes to mind everytime I look at those markers. pure freaky secks.
Trust
*AO*IO*KUSA*PBN*PHOG*
You have been roshamboed
BAMF-Hacker's Mood: HAPPY HAPPY HAPPY!!!!
Old 03-23-2007, 06:41 AM
Pwgsx's Avatar
300 fps
Default Re: LP help
so heres what im thinking......... AKA Valve or Madmans , do you not change the springs on the madmans??
I wouldnt mind a better bolt w/ orings but want a anti-chop one?? Is there one??
I have the AKA Lightning bolt but its not nylon, is it ok to use?? Also, it only has one grove on it for the balll detent, do I need to mod the other side too??
