Old 03-21-2007, 07:05 PM
Raiderz628 Raiderz628 is offline
Default Pilot chopping
I am new to paintball but I have a pilot and bought a Tiller 21 in barrel the first time I took it out it chopped pretty bad. I tried it again and lowered the air and it didn't seem to chop. I am using proto and impact paintballs.
Does the air pressure make any differance in chopping on a longer barrel?
Also should you use a silcone spray on the gun.
thanks
Old 03-22-2007, 01:54 AM
Default Re: Pilot chopping
-no silicone. Are you getting barrel breaks or breech chops?
Old 03-22-2007, 06:10 AM
shunut's Avatar
shunut shunut is offline
Respected, period.
Your barrel is HUGE. The first think I would do is get rid of it. It is doing you no good. Having a long barrel does not help you accuracy, it just wastes air. Get rid of it and get a new barrel no bigger that 16".
Viva La KUSA!
KUSA Feedback
2006 Non-Spyder of the Year - The Shunut Spimmy
Shunut Creations
Old 03-22-2007, 11:36 AM
STRIKEFIRST STRIKEFIRST is offline
I had a Taso Vindicator (That's a pump from back in the day for you youngsters) With a 20 inch barrel and a 6 inch silencer on top of that (Yes silencers were legal once.)...
Trust me you you don't need to shoot anyone...you can scare em out with that barrel!
05 Pilot ACS - SPPS Dragon tail trigger, 50 gram switch, CCM feedneck, ACP Bolt, Sticky 3's, Trinity -7 deg. V/A, Rocket Valve, DH Titanium Striker, BL Torp., T board w/ Eyes, Cp Direct Mount On/Off, 275 fps@250 psi
VS2
Black to Olive PM6
"All men have fear. The brave ones lay it down and go forward...some unto death but all to victory!" - Kings Guard of Ancient Greece
OLD FART CLUB MEMBER
My Feedback
Old 03-22-2007, 02:18 PM
Thanks What do you think about the Spyder Fasta hoppers would that hook up good with a Pilot
Old 03-22-2007, 02:26 PM
The balls were breaking into the hopper I switched hopper twice before I went back to my 14 in barrell
Old 03-22-2007, 04:26 PM
hopper blowback can be resolved. What are you chronoing at? If you are close to or over 300 fps, then turning down the velocity will also help with "popcorning" in the hopper. If you are unfamiliar with adjusting velocity; turning the knob in(clockwise) increases velocity, and vice-versa. Here are some Kingman tutorial links also:
http://www.kingman.com/section/suppo...os/videos.html
Good luck.
