Old 01-05-2007, 04:19 PM
tnballer tnballer is offline
Question acs bolt
while breaking in my bolt i have noticed that in the diagram it shows the bolt having 2 o rings on it but my bolt does not what is up with that why dont i have o rings on it and does it need them there really is no place for them
Old 01-05-2007, 06:05 PM
Halucin8's Avatar
Halucin8 Halucin8 is offline
Halucin8ns
Default Re: acs bolt
there are no orings on an acs bolt. that is one of hte few reasons to change it. bolts with orings seal better and keeps blow back from happening
Dragun T-1-clamping feedneck,Torp hpr,Micro-Rock LPR.
Pilot ACS-Low-Blow bolt,cocker feedneck,T-1 Hpr, turbo valve,polished
DragunFly-T-1 LPR,T-1 HPR
Dragunfire-TES Hpr,Polished
Rebel-Half-backed(by me)
E99
Xraider
Black LCD Fasta
Old 01-05-2007, 06:11 PM
do u have any suggestions
Old 01-05-2007, 07:44 PM
Its not supposed to have o-rings, the design doesn't work with o-rings. Why? The o-rings create drag if they seal well, the drag causes the acs bolt to compress as it moves forwards just enough so that it doesn't cup the ball, you'll get major blowby issues and possible unexplainable chops caused by turbulence.
Old 01-06-2007, 03:14 AM
Bandit Bolts Paintball sells delrin bolts with o-rings for low pressure and high pressure set-ups, that don't swell with oil. There are no ACS bolts with o-rings available from any manufacturer. Alamo also has o-ring bolts made from delrin. Check out my review of the Bandit:
http://www.pbreview.com/products/reviews/2903/
Alamo bolts:
http://www.alamocitypb.com/MANUFACTPAGES/kingman.html
Old 01-06-2007, 07:11 AM
DRAGON's Avatar
DRAGON DRAGON is offline
sna'foo.....um.....gesund heit
There are 2 types of ACS.....plastic and metal. Maybe the one you saw w/the o-ring was made of metal -
KUSA Old School Alumni #4939
Posts: 14,000+ before the old mothership went down
Jealousy is the tribute mediocrity pays to genius while feeling alone apposed to smiling adversaries....
http://www.spyder.tv/forums/image.php?type=sigpic&userid=6&dateline=1201845216
Old 01-06-2007, 08:43 AM
sidekick's Avatar
sidekick sidekick is offline
The drawing that Kingman sends out with the 05 Pilot ACS is of the Pilot. It does not have an ACS bolt. If you look closely at the drawing you will notice a few other differences; bolt, trigger frame, barrel and drop forward are all different.
If you make it idiot proof, someone will make a better idiot.
Feedback: http://www.spyder.tv/forums/showthread.php?t=6645
Old 01-06-2007, 11:22 AM
spider_pilot06 spider_pilot06 is offline
if there isnt a place for the o rings then dont worry about it millions of people have the pilot acs like me and fine
