Old 01-01-2007, 01:49 PM
boomerisnuts
Posts: n/a
Arrow Cup seal
how do i fix it because mine is leaking. i know it involves sanding but what kind of grit and how do i do it?
Thanx
boomer
Old 01-01-2007, 02:59 PM
Fury123's Avatar
Fury123 Fury123 is offline
i'd tap that...
Default Re: Cup seal
i had the same problem but i returned my pilot and they told me it was the valve...make sure u check the valve, but this is what Halucin8 told me,
take the cupseal out and lay a piece of very smooth sandpaper 1000 grit or better and put it on a flat surface then rub the cupdeal in a figure 8 motion a couple of times then reinstall. should work much better
Old 01-01-2007, 03:25 PM
boomerisnuts
Posts: n/a
thanx for the info uh where could i get 1000 grit sandpaper? wally world doesnt have it and i havent been able to look in home depot yet.
boomer
Old 01-01-2007, 04:12 PM
vikingshadow's Avatar
vikingshadow vikingshadow is offline
Ah-roo! Ah-roo! Ah-roo!
Look in the Automotive section - the Wal-Mart here carries it there.
I didn't even know about the sandpaper thing...cool tip!
Never argue with an idiot; they'll drag you down to their level and beat you with experience." ~ Anonymous
Old 01-01-2007, 06:37 PM
Halucin8's Avatar
Halucin8 Halucin8 is offline
Halucin8ns
it flattens out the seal and roughs/softens the sealing edge to make a better seal. when i went to the 32 degrres turbo valve i went through all three of my cupseals and none of them would seal. Once i sanded down the sealing side making sure it was flat and soft i haven't had a problemn in months and i shoot atleast a case every sunday in the woods.
Dragun T-1-clamping feedneck,Torp hpr,Micro-Rock LPR.
Pilot ACS-Low-Blow bolt,cocker feedneck,T-1 Hpr, turbo valve,polished
DragunFly-T-1 LPR,T-1 HPR
Dragunfire-TES Hpr,Polished
Rebel-Half-backed(by me)
E99
Xraider
Black LCD Fasta
Old 01-01-2007, 07:05 PM
Lapco makes a great replacement:
http://www.pbreview.com/products/reviews/597/
Old 01-05-2007, 05:26 PM
tnballer tnballer is offline
just about every automotive shop carries it its used to wet sand cars
on another note would regulating the air preasure help with this
