Old 04-03-2007, 11:53 AM
Firekillernmp's Avatar
Firekillernmp Firekillernmp is offline
firefight in the woods
Default "Air" co2 Vs. hpa
ok does hpa mean high pressure air if not what does it mean? what is better(co2 or hpa)? and can a place like academy fill hpa? sorry for all the questions , new and still trying to learn... thank guys
Old 04-03-2007, 11:58 AM
Critical's Avatar
Critical Critical is offline
I didn't do it...No witnesses survived
Default Re: "Air" co2 Vs. hpa
air, hpa and nitro all refer to the same thing.
Old 04-03-2007, 03:42 PM
spyderpilotacs05's Avatar
spyderpilotacs05 spyderpilotacs05 is offline
I have a sick wrath!
hpa is better for your marker but if you are new you dont need it rate now. It is also more consistant.
Old 04-03-2007, 05:43 PM
Picchi's Avatar
Picchi Picchi is offline
Motocross, Offroad buggies, wakeboarding...now paintball!
With CO2 performance depends on temperature as well. For instance, if you fire rapidly with your marker, there is going to be a time when your gun will end up taking in the CO2 as a liquid, freezing your internals for a bit and possibly damaging your O-rings. If the temperature is below 50 or so then you might get some freeze ups, but if you are in warmer weather...then not as much of a worry. The HPA is definitely better and more consistent for the marker and the prices for the heavy steel ones aren't that bad. It kind of protects your investment in my opinion. Saying that I know many happy players with CO2.
Spyder MR2
MX4 Stock
BSA RedDot Scope
BT Apex
14" J&J
Draxxus Pulse
Tippmann Triumph
VerC T-board
HPA w/remote
PCS US5 (Spider threading!) BACKUP MARKER
Old 04-03-2007, 10:09 PM
cool!! thanks!! and can they be refilled at the same store that co2 can?
Old 04-04-2007, 04:52 AM
Critical's Avatar
If you're getting your fills at a paintball shop, they should be able to fill air. Anywhere else, like Sports Authority or Wal-Mart, probably not.
