Go Back   Spyder Forums > General Spyder Discussion > Veteran Forum
Old 01-25-2008, 06:39 PM
pinkanese's Avatar
pinkanese pinkanese is offline
Default Help aligning eyes
Well basically as far as I cna remember when I drilled the holes for my eyes I didn't have the 3mm bit I needed so I wallowed them out to make the eyes fit. Now of course my eyes don't line up perfectly so they don't work, I have taken off the covers and if I wiggle them a little I can get them to work, but as soon as I put teh covers back on it is the same problem as before. I am wondering if anyone has an idea on how I can shim the eyes or something ot get them to work.
EM1 w/ OTB Frame, 'Winder, etc.
Kingman Hammer, soon to get a sister, or two.....
FEEDBACK Post Here!
MCB Feedback
Old 01-25-2008, 07:23 PM
MVS1's Avatar
MVS1 MVS1 is offline
Finally!!!
Default Re: Help aligning eyes
What board and eyes are you using? the SD laser eyes are less finiky (sp) when it comes to alignment than IR eyes, so that might be an option for ya.
Never go Bear hunting without a sandwich...sandwich: someone you can out run or don't mind shooting
Angel 1 Non-SOM Apr 07
Ripper 3 Non-SOM Apr 08
Family Photo
My Feedback
Old 01-25-2008, 07:25 PM
pinkanese's Avatar
Well if you must know the type of board, it is a Frenzy 110. I know there are EYEs available taht allow up to 20* or so of misalignment, but I don't want to spend anymore money on this than I already have.
FEEDBACK Post Here!
MCB Feedback
Old 01-25-2008, 11:18 PM
so the eyes are what - 2.5mm and you bored a 3mm hole?
You could try short pieces of shrink tube that take up the slack inside the drilled eye hole; or 4 SMMMAAAAALLLLLL dabs of epoxy resin applied to the hole in the 4 poles...since it's usually pliable, they should "give-way" enough to let the led in and hold it in place...
