Old 11-04-2006, 08:58 PM
sactowns finest's Avatar
sactowns finest sactowns finest is offline
Sacramento Kings Rule
Default Regulator troubles
there is something wrong with the stock regulator on the rodeo. it seems like the air flow is really low. it makes the gun sputter and wont shoot. i thought it was the valve but i changed it and its still the same. when i put on a full tank the gauge says its about empty. i dunno what to do.
Old 11-04-2006, 09:04 PM
vwjimmy's Avatar
vwjimmy vwjimmy is offline
Here, there, everywhere!
Default Re: Regulator troubles
Did you try to adjust it? (Allen on the bottom)
Welcome to the forums!
Angels, Timmys, ICD Bushy, Pimp, and lots of Spyders
Old Farts Club
Member #12
"Your marker cannot harm me...I'm the Juggernaut!!"
KUSA Feedback +56/-0
New PBN Feedback +20/-0
Old PBN Feedback +92/-0
Old 11-05-2006, 05:04 PM
rodeoshooter's Avatar
rodeoshooter rodeoshooter is offline
***Rodeo Owners Club***
Start with the allen screw airflow adjuster all the way in and cock the bolt. Then put your tank on. Unscrew the adjuster slowly and check your guage as you do. Your pressure should rise. And the adjuster on my Rodeo is on the side of the foregrip (black allen screw). Are some Rodeo's on the bottom, Jimmy?
***There's no crying in Paintball***
Old 11-05-2006, 05:41 PM
vwjimmy's Avatar
Yea.....
My Fenix has the same reg as a Rodeo and it has a bottom adjuster...
Old Farts Club
Member #12
Old 11-05-2006, 05:46 PM
My gas line attaches to the bottom, so the adjuster is on the side. That's the way the Rodeos I've seen are. Wherever it is, threadstarter, try it as we've suggested and let us know how it works out!
Old 11-05-2006, 07:36 PM
ok ill try it thanx
Old 11-06-2006, 07:10 PM
its still sputtering and when i shoot the ball barely goes 10 feet
Old 11-07-2006, 12:08 PM
1) You're sure the tank is full?
2) Do you hear a leak anywhere?
Old 11-07-2006, 04:17 PM
ill try to use a full tank tomorow. no i didnt here any leak
Old 11-07-2006, 05:39 PM
Did you adjust the reg before this happened? Make sure your valve is in the correct way aswell. Another thing to check is if a friend of yours has a spyder to try his non-reg asa and see if it really is the reg or not.
