Old 10-16-2007, 03:45 PM
AMP Warrior AMP Warrior is offline
Why can't paint be cheaper...?
Default I'm New and i got a prob w/ MR1
Ok im new. actually this is for my PB team. We got alot of spyders and some other guns, but mostly spyders. Now to the point. I think i read on another thread that you can push the cocking pin down in order to use the sight. I can push it down but only when the spring below it isn't in. the cocking pin has clicked into place but wont go down. I can push it down a little ways but it will just pop up. It wont lock like it will when the spring isn't there. I just want to know if i have assembled my gun wrong, and if so how do i fix the problem, or is this the way its supposed to be.
Old 10-16-2007, 04:18 PM
Default Re: I'm New and i got a prob w/ MR1
Oh and another thing. I have a problem, as i think many of you have had, with the stock. I can't see down the barrel with my mask on. I saw that one person cut theirs off. I wana know if this is a good idea, if i do do it then how will it hold up, or should i put a dot sight on?
AMP
IF YOUR PARENTS DONT PAY FOR YOU TO PLAY PAINTBALL PUT THIS IN YOUR SIG
Old 10-16-2007, 04:43 PM
SupaSnipa's Avatar
SupaSnipa SupaSnipa is offline
The Gumpster
you should put a red dot scope on it but unless you saw the top bar off (yes its a good idea) you wont beable to see the sight unless you get a raised sight rail. If you saw off the bar you wont need a riased sight rail
"You gas up the marker, put on the gloves, strap on the mask, and walk onto the field.. it doesn't matter that you failed a test, that your girlfriend broke up with you last night, or that you got a ticket on the way there. Your world is right for the next couple hours. This is your heaven on earth. Live it. Love it. Paintball for life."
Red Proto jersey, USED ONCE!
Old 10-16-2007, 05:01 PM
OK thanks. But what about the firing pin? Should it lock so i can see down the rear sight? or is it supposed to hit the spring for the striker?
AMP
Old 10-18-2007, 05:01 AM
agurish's Avatar
agurish agurish is offline
The pin is a small matter if you get a rail that is either "raised" or "offset". There are *many* manufacturers that make attachments for the picatinney/weaver rail that is on the top of the MR-1. You have multiple choices here, so I'll go over them briefly.
1.) Raise the sight rail over the cocking pin. Avoids the stock and pin.
Here's a link for a part that'll do this:
http://www.cheaperthandirt.com/ARR170-63652-1887.html
2.) Offset the rail to the left, thus avoiding the cocking pin altogether.
http://www.bp-usa.com/accessories.htm
3.) Tilt the rail to the left 45 degrees, avoiding both the stock and pin.
http://www.cheaperthandirt.com/ARR9691-63747-1887.html
There you go...
-AGURISH
Old 10-18-2007, 12:44 PM
Thanks alot. I will do one of those.
AMP
