Old 11-10-2007, 04:16 PM
theklu theklu is offline
Default dang, low fps!
well, i lost the washer thingy between the striker bolt and the velocity adjuster (any have link to officiall mr piece washer?), i went to the hardware store and make a make shift one that worked last time out, but went to a field today and i had my velocity adjuster turned in all the way and i was averaging 200-240fps...I tried to stretch out the spring but it didn't help, suggestions for getting my fps back?
(note, i didn't strip my gun from the last time, and didn't oil it before hand - altough i shot oil through it a month ago when i used it last
***edit***
any luck with these spring kits? trinity spring kit (4 springs) or the diablo mongoose spring kit (only three springs, but bolt springs too?)?
trinity http://www.actionvillage.com/is-bin/...EAAAECexwmO7IN
mongoose http://cgi.ebay.com/New-Diablo-Spyde... QcmdZViewItem
Old 11-10-2007, 05:37 PM
vikingshadow's Avatar
vikingshadow vikingshadow is offline
Ah-roo! Ah-roo! Ah-roo!
Default Re: dang, low fps!
It's called a Striker buffer. Going through Froogle, here's what you get...
http://www.google.com/products?q=striker+buffer
You might be able to find a used one cheaper somewhere.
The Trinity spring kit will work - it's not a bad price for those springs.
Never argue with an idiot; they'll drag you down to their level and beat you with experience." ~ Anonymous
Old 11-10-2007, 06:18 PM
chnk's Avatar
chnk chnk is offline
Mountian Dew sponsored
you definitly need the strikfer buffer,
acp sells some derlin ones for like $10 i think
Old 11-12-2007, 05:52 AM
but a washer of equal size did the trick the last time i went out...but i will pick up the striker buffer
