Old 06-20-2006, 03:10 PM
M!KE M!KE is offline
Default Spyder Operating Pressure
Hi, I am new to paintball and am interested in getting an evil detonator regulator. I read the specs on it and says it regulates pressure between 100psi and 500psi. I was wondering if a stock spyder would run on that 500psi and if it doesnt what parts i would need to get it to run at that.
Old 06-20-2006, 03:21 PM
shunut's Avatar
shunut shunut is offline
Respected, period.
Default Re: Spyder Operating Pressure
Probably not. Out of the box spyders run at 800-850 psi.
Viva La KUSA!
KUSA Feedback
2006 Non-Spyder of the Year - The Shunut Spimmy
Shunut Creations
Old 06-20-2006, 03:38 PM
ShadowX's Avatar
ShadowX ShadowX is offline
ECLIPSE FTW
Well, Strangely enough, I have a Story..
I bought an AKA 2-Liter Reg (LP version 0-350 PSI) for my ION..
Well, When I need to lube it, I cannot lube it on the ION because the Reg oil that goes through the Reg can damage the ION's Soleniod..
So, I Put it on my Back-up E-Framed Spyder.. Has an ACS bolt, Spring kit, and E-frame.. Nothing else.. My Reg is supposed to top out at 350 PSI.. So, I lubed the Reg, Put it on the Spyder and turned it All the way up (which is supposeively 350 PSI).. It recocked.. And it seemed like it was shooting normal.. Weird, I know.. I didn't run any paint through it, But It dryfired about 300 Shots and no Burps or Jackhammers..
I have no guage on the Spyder so IDK What pressure the Reg is REALLY at when turned all the way up.. But, AKA says, for the LP version (which I have), it is 350 PSI..
So, All in all I have a Stock Spyder TL-X that recocks at 350 PSI.. :/
http://www.spyder.tv/forums/showthread.php?t=158
^ ^ ^ ^ ^ TRUST ^ ^ ^ ^ ^ ( + 12, - 0 )
Blue Dynasty ION - HP PMI 68/45 - Smoke Vlocity
ULTIMATE PAINTBALL INC.
www.ultimatepaintballgeorgia.com
Old 06-20-2006, 10:03 PM
bungeye bungeye is offline
The Idiotic Kiwi
maby the reg provides constant pressure at a max of 350psi, but you could be runing at 800psi but it changes and isnt constant.
My 3 life mottos
1) Buy in bulk and save
2) Cutting in line gets you nowhere, except to the front of the line
3) If something has gone wrong. Its easy to blame yourself, but its EVEN eaiser to blame someone else.
Old 06-20-2006, 11:22 PM
DRAGON's Avatar
DRAGON DRAGON is offline
sna'foo.....um.....gesund heit
Originally Posted by ShadowX
.....Well, When I need to lube it, I cannot lube it on the ION because the Reg oil that goes through the Reg can damage the ION's Soleniod....
I'm thinking that can be negated if you use the correct oil. I doubt running 1 or 2 drops of say 20 weight 100% silicone oil through it will hurt it. They sell it for RC cars as shock lube for like $3 a bottle. You can get it at your local RC hobby shop in different weights from like 10w to 90w in increments of 5. I've used 50w on my Imp for the past 4 years and it has never missed a note -
KUSA Old School Alumni #4939
Posts: 14,000+ before the old mothership went down
Jealousy is the tribute mediocrity pays to genius while feeling alone apposed to smiling adversaries....
http://www.spyder.tv/forums/image.php?type=sigpic&userid=6&dateline=1201845216
Old 06-21-2006, 06:49 AM
EstebanFR's Avatar
EstebanFR EstebanFR is offline
Hi, i think that your spyder can maybe run at 500 PSI. Normaly, spyder run at 800 850 PSI. But 2 spyder rodeo or 2 spyder electra are...different. Yes, one can run at 800 and not under and the other, same model, can run a 500 or lower! Why? not exactly the same part inside. A friend of me hs a spyder rodeo and without any modification he can run his rodeo at 300 PSI without any problem. Yes, but the velocity is 250 260 FPS ;-).
So i think the best way to know, is to try.
And if u know a guy who have the same spyder like u, and if he cant go under 800 or 700 it meens nothing for u, u need to try on your gun.
good luck.
Old 06-21-2006, 07:44 AM
ShadowX's Avatar
ECLIPSE FTW
Yeah, Drago, The oil I am using in the Reg was this stuff I got straight from AKA.. They swore up and down that it was different from Gold Cup oil (which I have).. So I bought it for 11 Bucks shipped to my door.. Turns out it is Exactly the same as Gold Cup.. Heh..
But I would rather be safe than sorry.. And I learned that my Stock Spyder Can recock at 350-400 PSI.. Lol..
Old 06-21-2006, 10:43 AM
I had a Sonix (didn't cost me $200 though )that I put an assault block on and a torp...polished the internals and had it running at 300 psi...no other alterations. I traded it to Tim who spent more than the 20 mins I did on it and it recocked at around 175 psi or so...Tim...correct? I maight be slightly off on the psi...but it was loooooow....lol
