Old 04-18-2008, 08:22 PM
kingswin82 kingswin82 is offline
Default How do I activate my response trigger?
Hey Guys,
How do I activate my response trigger on my Pilot?
Thanks
Old 04-18-2008, 08:32 PM
DFSniper's Avatar
DFSniper DFSniper is offline
Official SOC Short Bus Crew
Default Re: How do I activate my response trigger?
it doesnt have a response trigger...
8/23/03 OS KUSA #10898
Spyder to pump conversion tutorial!
Project LP Reposted!
Sales Thread
(7:11:05 PM) Battlechaser: Did you just slaughter George Clooney and steal his mojo..?
"Death doesn't exist. It never did, it never will. But we've drawn so many pictures of it, so many years, trying to pin it down, comprehend it, we've got to think of it as an entity, strangely alive and greedy."
- from Ray Bradbury's Something Wicked this Way Comes
Old 04-18-2008, 08:33 PM
TheDarkShadow's Avatar
TheDarkShadow TheDarkShadow is offline
add 1,794 posts
your e-frame? charge battery, turn the switch on, press button in back to change modes
E-framed Sonix Pro
2009/2010 bone stock sonix
Old 04-20-2008, 06:54 PM
In all the descriptions of the gun it says "Reactive Response Trigger".
Old 04-20-2008, 07:14 PM
add 1,794 posts
where are you reading these descriptions?
E-framed Sonix Pro
Old 04-20-2008, 07:44 PM
XSiv Force's Avatar
XSiv Force XSiv Force is offline
What is The Dew, and How Do I Do it
Response triggers are Tippmanns frame spyder doesnt have that
Originally Posted by slim and shady View Post
XSiv you and your nipples take the cake
Proudly Surrendering people at 25 yrds
Old 10-03-2009, 01:06 PM
chl2onic's Avatar
chl2onic chl2onic is offline
I think the reactive response just means it reacts to you walking the trigger.. As in even if you are only walking it at 10bps, it will see this ramp in speed and just shoot at it's cap... don't quote me, but I think thats what it means.
Old 10-03-2009, 03:06 PM
ferret15's Avatar
ferret15 ferret15 is offline
09 SOTM WINNAR!
i think Kingmans lingo means
When you pull the trigger you hit a micro switch. The board then recieves this input and then actuates a solenoid that trips a sear.
contact me for custom work
Feedback +18/0
Old 10-03-2009, 04:47 PM
XSiv Force's Avatar
dead thread revived...........zombie thread...................
Old 10-03-2009, 08:52 PM
oldironmudder's Avatar
oldironmudder oldironmudder is offline
EM1 Tech guy
Very true.. 4/20/08!!
Anyway since im kinda bored:
Originally Posted by my old site
Reactive Trigger Response
As you have read in ads & the manual that the kingman E-frames have this mode but after fiddling with it for a while you realize that its not on there. Dont get your pants in a wad, you can have it but only for a little bit of work.
First a bit of history, RTR is when a electric paintball marker cycles on the pull & release of the trigger. It is a poor mans turbo mode really.
WARNING: I suggest that you read all directions before you do this mod. I will not be held responsible if you mess up your trigger frame, hurt yourself or the family pet. All I did was provide the information to do this mod.
Materials
~1 SPST switch
~1 10" or more piece of wire, 20gauge works fine
~Solder if you want to keep it a long time, other wise some electric tape
~Few inchs of heat shrink to cover the soldered connections
Step 1:Take the grip frame off the body. Remove the grip panels & disconnect the battery. Look around inside to understand how the parts go. Find the trigger switch now.
Step 2:After you have found the trigger switch look on the rear of it & you will see 3 leads, 2 have wires & the other is bare. What you are trying to do is connect the bare lead with the middle lead with a switch os a on-off.
If you can tap out the pins holding the trigger & switch.Just leaving the switch in will make this harder because of the cramped space inside the frame.
Step 3:Take your wire & strip between .25" - .5" of insulation off. Connect one wire end to the middle lead & the second wire to the bare end. If you are soldering the connection this is the time to do so. If not, cover bare wire with some electric tape.
Step 4:Time to find a mounting spot for the switch. When I did this mod, this was the hardest step. You can drill a hole into the grip panels, mill out part of the frames by the body to help hide the switch. Just find a spot you like & wont be hit & come on by it self.
The second time I did this I used a small SPDT slider switch, like stock on-off, & mounted it in the window ofthe panel. It was short enough so it wouldnt hit the dip switchs or any other parts of the board.
Step 5:Put a battery into the frame & turn the frame on. If you hear the noid click the mod is working. If not & you installed a switch flip the switch & the noid should go off. Now go out & play with it a while.
F/S/T:
WTB: WTB List
Feedback: 120+
