Old 05-20-2007, 05:54 AM
oscar oscar is offline
Deadly Shot
Default bolt problem
i gun have 05 electra acs, i can not figure how to get the top cocking bolt out
the screw in the back is stripped i guess i bought the gun new and could not get it out i have taking the whole rest of the gun apart except for this and the striker of course, can not get one out with out the other,help?????
Old 05-20-2007, 08:50 AM
Kenny_McCormic Kenny_McCormic is offline
WILL WORK FOR PAINT!
Default Re: bolt problem
you pull out the cocking pin from there im pretty sure the bolt just slides out
Stock ZAP AMP generator with polished valve assembly
Spyder Victor with a modded CORE derlin bolt, polished striker and polished valve assembly
BEING POOR SUCKS
Old 05-21-2007, 04:31 AM
Deadly Shot
Unhappy Re: bolt problem
no it does not pull out the set screw in the back holds it in to far that is the way i got it new now the head is messed trying to get out
Old 05-21-2007, 08:48 AM
kidonfire's Avatar
kidonfire kidonfire is offline
If you fall down a bottomless pit, you die of starvation.
Location: Thumbing my way home on the side of the interstate
There is a screw in the back of the bolt. It's hard but loosen it a little to see if that helps.
10% luck, 20% skill, 15% concentrated power of will. 5% pleasure, 50% pain, 100% reason to remember the name.
Everything you need to know
Old 05-21-2007, 12:04 PM
yeah its loctited needs heat hold a lit match up to it as long as you can then try unscrewing it
BEING POOR SUCKS
Old 05-21-2007, 01:24 PM
pb34's Avatar
pb34 pb34 is offline
Not too new guy
Try using a pair of pliers to get the top cocking pin out. You might be able to get it out that way. Otherwise you'll have to try to loosen the screw on the back of the bolt.
Almost finished LP Pilot
<<XX PILOT OWNERS CLUB # 36 XX>>
The Official Manual Thread
Spyder Feedback
PBN Feedback
Old 05-21-2007, 01:56 PM
xSoulsx's Avatar
xSoulsx xSoulsx is offline
Ummm
I have the same problem witht he bolt thing it comes out like half way but then its just really hard to get out....
Blue/Black Special edition PMR
Halo B
DXS 48/45
Old 05-21-2007, 02:12 PM
pb34's Avatar
Not too new guy
You have taken the cocking knob out right? Well if its coming halfway out you need to turn on the trigger frame and shoot it a couple times while pulling it out. The reason it won't come out is because the sear is sticking up and preventing it from coming out. Pulling the trigger pulls the sear down. So while pulling the trigger pull out the bolt at the same time.
Spyder Feedback
PBN Feedback
Old 05-21-2007, 03:33 PM
xSoulsx's Avatar
Ummm
Oh, the white bolt? Yea I know you have to shoot to get it out...I thought he ment the cocking PIN...The one you need to use to cock the bolt... Hehe OPPS
Halo B
DXS 48/45
Old 05-21-2007, 03:49 PM
pb34's Avatar
Not too new guy
Oh he is talking about the cocking pin, I thought you were talking about the actual bolt.
Spyder Feedback
PBN Feedback
