Old 11-16-2007, 10:10 AM
Varent212 Varent212 is offline
Varent
Default New here: want to deck out my gun.
I got an mr1 recently and am going to start moding. I figured that you could help point out how i should start the process. I know i should change out the barrel and am going to get an anti syphon kit for it to start in the winter. but also I need to know if anything else is recommend it to make my mr1 fool proof for the winter. I was reading that put rain-x in your barrel can give it a ceramic effect. has anybody tested this? if so let me know because it sounds like it would work just fine. should i take out the venturi? and also should i change the stock or modify it by cutting the top off of it? seems like that would mess up the integrity of the stock. so many questions that i hope someone can answer. if anyone has any other questions then please post on here so it can be answered for me too if i didnt know.
--My Kit--
  • Spyder MR1
  • 16 Inch barrel
  • Trinity Feedneck
  • Remote (works fine to my standards)
  • Evolution Electric Hopper (Need new shell)
  • Spyder 20 oz CO2 tank
  • Stock (Now Dogfooted)
  • Barska Red Dot Sight
  • Spyder Compact Elite trigger setup
Currently working on rebuilding my spyder e99 for speedballing. Its gonna be sick!!!
Do you pay for your own Paintball addiction? I do
Old 11-16-2007, 10:17 AM
deano 177's Avatar
deano 177 deano 177 is offline
don't let your meat loaf
Default Re: New here: want to deck out my gun.
I have never heard of that "mod". If you try it let us know how it works...
Some folks do that so that they can sight down the barrel a little more accuratly. I don't like how the stock setup felt so I don't use mine. I have no idea how it feels or how it affects the rigidness of it.
SOCTrust
PBNTrust
Old 11-16-2007, 11:24 AM
TheRedBarron's Avatar
TheRedBarron TheRedBarron is offline
RaWr
Welcome to our humble home, first off I would like to point out that the rain-x in the barrel is a myth it does not help it as a matter of fact it leaves a residue inside of the barrel which may or may not affect the balls flight due to the fact that it cannot be spread evenly inside of the barrel (I have not heard of this "mod" for some time its kind of nice to hear about the old ones coming back) if it cannot be spread evenly inside of the barrel then it will cause a spin on the ball which in turn affects your accuracy due to the fact that a paintball is not perfectly round.
Get anti siphon but make sure you have your shop install it for you, bring your marker and tank into the shop so that it can be properly installed, also another good thing to do for a co2 tank in the winter is to wrap it up in something to help keep the temp a little higher, I remember using a wool stocking to cover the tank and I also used to tape those instant hand warmers to the tank to help bring the temp up to what it would be on a nice spring day. Granted this is not fool proof but it does make a difference.
Removing your ventri gives results, when I was using stock bolts on my spyders I always removed the ventri make sure you do it properly and try not to scratch the bolt when you are doing it, I dont know if you have seen Otters site yet or not but it gives you step by step instructions on many mods similar to this one. Click here
As for the stock that is completely up to you, personally I would not know much about it as I have not really toyed with and MR series marker any more than teching it at my shop. So I would wait for some more advice from someone with more experience in that field before doing anything of that sort.
Once again welcome to the boards, if you have any other questions pertaining to paintball or in general you will find that the other sections of our boards are a little broader and most of your questions will be able to be answered in the general section and the veterens section, no question is considered stupid here so feel free to ask away. Hope this helped some
<3 TRB
"If society is tranquil, it is not because it is conscious of its strength and its well-being, but because it fears its weakness and its infirmities; a single effort may cost it its life. Everyone feels the evil, but no one has courage or energy enough to seek the cure."
Old 11-16-2007, 07:57 PM
cyberthrasher_706's Avatar
cyberthrasher_706 cyberthrasher_706 is offline
MR's 4 Sale
Welcome!
I answered your stock question here
http://www.spyder.tv/forums/showthread.php?t=13813&page=2
Let me know if you have any other questions.
Originally Posted by snipehunter
Oh, and what do we put in our signature if we've graduated college, work full-time, and WISH our parents paid for paintball?
Old 11-20-2007, 12:10 PM
cansniper cansniper is offline
I have been playing for a number years now and can shed some light on the Rainx in the barrel "mod".... When you put rainex in your barrel you need to spread it around with a cheap barrel swab...walmart sells them, they are a wodden stick with wool glued to them. Pour the Rainx in the barrel and the push the swab back and forth down the barrel while twisting it around. This will spread the Rainx evenly on the inside of the barrel.....NOW...this does nothing for the accuracy of the gun whatsoever (either good or bad) in my experience. What it does do is allow the barrel to clean itself if you have a ball break. By firing the gun a few times, the paint will slide out of the barrel much easier, and allow you to keep playing instead of having to remove and squeegee your barrel out. Also, if you can turn your loader off so that there are no more balls entering the bore, you can then hold your hand over the end of the barrel and fire the gun a few time to clear out the barrel ports.
Old 11-20-2007, 06:04 PM
MR's 4 Sale
don't they make barrels that do that now?? I sure hope so since I bought it. I don't know, I don't wanna sound mean with that one. I just don't like the idea of pouring a chemical into something that's so sensitive with it's tolerances. Besides, they make barrels that are already ceramic just for that.
Old 11-20-2007, 06:21 PM
oldironmudder's Avatar
oldironmudder oldironmudder is offline
EM1 Tech guy
I used to do this all the time. I never tested it in a shot to shot contest to test FPS but it really helped out on a ball break. Apply it evenly you ask? I use an old BE squeege & a fold piece of paper towel. Line it up on the squeege, put Rain-x & it & run it down the barrel.
F/S/T:
WTB: WTB List
Feedback: 120+
Old 11-23-2007, 07:02 AM
Hey, ur right the ceramic barrels will do the same thing. I shoot a freak system thought and the rainx really helps. Ur also right that you want to make sure u spread it evenly throught the barrel so that you don't get tolerance issues.....and you dont have to use a lot...a very thin coating is all that is needed. You can also wash any excess out with a little bit of water.
Old 11-26-2007, 11:43 AM
Varent
Thank you for all the answers. I have seen the otter site and it has some very helpful info. I am not a newb to paintballing, just not a vet .... yet. I have played for a year or so and am just now having the cash to start playing regularly. I had to buy the mr1 because it looks like a lot of mod oppertunities. once again thank you for the replies. I look forward to being part of this forum and the forum community. My next question is that I would like to find out the best way to paint your markers. I have someone who will supply the materials for free if i help him figure out how to paint the markers. I could just slap the paint on but I want the paint to stay on.
--My Kit--
  • Spyder MR1
  • 16 Inch barrel
  • Trinity Feedneck
Old 12-06-2007, 10:36 AM
MR1_SNIPER's Avatar
MR1_SNIPER MR1_SNIPER is offline
Run as fast as you can, I still have a clean headshot
A new barrel would be a good idea but make sure that it will have a positive effect on the gun as far as distance and accuracy. Rain-x spread evenly inside of the barrel will help a ball-bust exit out of the barrel in a matter of a few dry shots. An anti-siphon kit is the way to go if you are operating on CO2 in the winter. An expansion chamber or remote line also helps the CO2 liquid transfer into a gas before entering the marker. Cutting off the top of the stock will help you by not preventing you from seeing exactly in front of you but still giving you a tactical effect. The venturi bolt is a great bolt but a delrin bolt from alamo city paintball will really help in the long run.
Spyder MR1
Rap4 CQB Barrel
BT-Apex Barrel(wed)
Rap4 M4 Expansion Chamber(fut)
Rap4 Spyder Carbine Buttstock
EVLution 3 Loader
Spyder Revolutionary Rocking Trigger 2.0 CAMd 3.0
G&P Tilted Lower Side Rail RIS Extension Mount
Rifle Cheek Pad Ammo Pouch
Heavy Duty Remote Coil Line
BSA 1 x 46 Red Dot
Neonfire Self-pressure Laser Sight
Spyder "low blow" delrin bolt
Spyder Delrin Striker(fut)
Bandit Bolts Spyder High Flow Air Valve
Velocity Kit
Pure Energy High Pressure Nitro Tank
